Has anyone replaced the blue front and rear badges as mine are tarnished inside? Can they be prised apart and re-furbished?
I've seen on here that some models have badges that are screwed on. Others glued on. If screwed on then there will probably be a lot of trim to remove.
I suggest get some decent fishing line and use as a saw behind the badge big careful not to damage surrounding paintwork
Prised apart and refurbished is not a realistic option sadly. iirc the badges are fully sealed....hth
