GS300 Brake booster abs malfuncion c1322
Joker
Hello fellow lexus owners
Im having a bad time with my mk2 gs300.
The brake booster started playing up, making squeaky noises then eventually stopped working.
So i found a replacement online (secondhand) and fitted it.
Now heres where the problem starts:
I can hear the brake booster working, making buzzing noise but the brakes are still bad, meaning the pedal is still going down and i have to double press the pedal to get the brakes working.
VSC, ABS, VSC OFF is still on
i did unplug the Battery when i changed the booster
i also bled the brakes
i connected it to obd, gave me a fault code
C1322 ABS MALFUNCTION
im literally out of ideas now, please can anyone help me
When i press the brake pedal the booster starts buzzing then stops after a minute or so. I didnt have how to test the booster i just took the guys word for it
Given that the pump stops it suggests it is working correctly. Normally they continuously run if they cannot create a vacuum until the system gives up and the alarm/warning lights come up.
It may not be bled properly.
BLEE.PDF
