New here guys so be gentle with me. 😁
I thought the 2011+ models came with a centre tach ?
Just been looking at the Silver 2011 in Lexus Guilford and no centre tac.
Was it only the US cars that had centre tac fitted?
Depends when it was registered - most likely its the 2010 model If it has the blue F panel at the bottom of the steering wheel with two equal sized speedo/rev counter. That model year was revised with a mechanical LSD.
Definitely a 2010 model - I guess it sat in a showroom for a few months before being registered.
Not sure how accurate the month is, but the year is correct:
940307382_Screenshot2019-05-01at20_41_21.thumb.png.db6c9510a8860c391da9f282d375fb00.png
Mines a 2011, with two dials rather than one. Quite normal.
You can actually put the new one on the older model and it works (almost) perfectly, and the swap is quite easy if you find the part.
better to get a 2011 model one though, that way you get the better suspension - although you can get the even better suspension in 2012, or the even better better suspension of the 2013 model 😉
