Hellooo everyone,
I've had my rx300 for just over a year and today the rear air suspension failed, but light on dashboard is showing normal can't hear compressor working and its completely low on the back end now. Front has been replaced with springs and shocks before I purchased it.... Please help thanks in advance for any suggestions. I'm waiting on parts to replace air suspension with springs and shocks.
Hi Steph and welcome to the club.
You may have a better chance of an answer if you post in the proper RX forum (I'm not really sure what purpose this "New Members Area" serves to be honest).
If you can't hear the compressor working it may be a power issue so I'd check all fuses and/or relays associated with the compressor and air system. I'm afraid I can't be of any help as I've never had air suspension on any of my cars (I've actively avoided it for the reason that it can be extremely expensive to fix when it goes wrong) but I'd say you're doing exactly the right thing in converting to springs and shocks.
22 hours ago, Stephanie Hand said:
Hellooo everyone,
Do you mean you have air at the rear and springs at the front?
Thanks herbie for the advice on checking the fuse/relays
Yes it has shocks &, springs on the front and air at the back, just waiting for parts coming Monday so I can covert the rear to springs. It's been ok for a year and all of a sudden nothing with the air suspension, its sitting completely low even though the dash light is saying its in normal mode and there isn't any noise coming from the compressor
Moved to the correct forum and duplicate removed.
I don't understand what advise you are looking for if you already have replacement parts on the way and intend to convert the air suspension to traditional springs?
I'm trying to locate what has failed and if it's an fixable as I'm 50miles away from home and whether I can fix it to get back or if the air suspension has gone completely, I've looked in the manual and it says any system failure on the air ride and it will stay in the normal ride position and it hasn't its completely flat on the rear. Obviously I don't want to drive it home in this position causing more problems. Herbie said check fuses/relays but it doesn't mention in the manual if there is any to check.
The air suspension main fuse is in the engine bay fuse box. I believe there is also a separate relay for the compressor.
There is also a smaller fuse in the cabin fuse box - the fuse positions should be shown on the inside of the lid.
Thanks Colin I will check them in the morning, keeping everything crossed that it's a fuse til I can get back home
The reason I ask is that we discussed this on another model and came to the conclusion its not possible to have half air and half springs, so it's interesting that you do!
Yes apparently one of the front air had a leak so he changed it to springs but the back was ok, all the pipes are still there if I wanted to change them back, I've driven it over 15k miles in just over a year no problems until yesterday but I have been on about changing the rear to springs to match the front as never had air ride before. I'm not sure why the person didn't change them all at once as that is what I would of done, if one goes then the others will surely go in time!!
Is it safe? It sounds rather unusual...
To be honest I've never know it before but like I've said I've drove it for over a year and over 15k miles and it's been sound upto now, I always had intention to change them over to all springs but other things always cropped up.
I don't think safety is an issue, and with the rear adjustable you can compensate for a heavy load in the boot.
The issue with only half a system is that you need to fool the ECU that the front is working correctly otherwise you will get a bunch of error codes. You could either move the front height sensors to the rear and extent the wiring or wire the front ECU sensor inputs into the rear sensors, that way when the rear suspension moves the ECU thinks the front is correctly moving too.
The guy who had it before has left all the wiring and pipes in the front so it's all there to change it back to air at the front if wanted.
I went to check the fuse this morning but unfortunately I couldn't get it out, started the car and still nothing tried everything it said in the manual, so I have moved the car to face the right way for recovery. Turned everything off that I could electrical wise ( heaters/ stereo) started the engine and the compressor kicked in so at the minute he's at normal air ride thank goodness, keeping everything crossed he's stays there so I can get back home 🤞🏻🤞🏻
  • Like 4
Thanks everyone for your comments, he got me home without failing and compressor seams to be working OK now,  all parts have now come and over the next few days me, my dad & bro will be doing the change over and then no more suspension failure... Fingers crossed 😊😊
Good news, and please update on how it drives when the work is done👍
Hi all,
The new springs and shocks are on and he drives like a dream, 3 days off the road but well worth it 😊😊
  • Like 4
