It's straight off http://www.lexus.co.uk - click the small icon at the top right of the head and shoulders and it will get you to register if you haven't already. You may be able to go straight to https://www.lexus.co.uk/my-lexus
Once in just add your vehicle details (I had to do it via the VIN from memory) and then it will add the car.
Once it's on you go to Vehicle Information and then there will be a Service History tab with everything listed under there. If you click each item it will expand with more detail.
If it's ever been to a Lexus dealer it should - has to be worth a go 🙂
Best place to look is Lexus used cars section on the website
Sent from my iPad using Tapatalk
On 6/29/2019 at 10:14 AM, aido said:
Have you checked the My Lexus area of the website - if you register your VIN there it will let you see everything that ever happened when the car was at a dealers?
You may find some surprises in there - I got more info from there than the stack of paperwork that came with my car with some good bonuses like the radiator having been replaced etc which I understand can be a weak point.
Thanks Aido - just checked and confirmed the near total lack of Service History!  Ah well, on with the catching up 🙂
Jim
