My IS200D F Sport has developed a fault in as much as the screen washer pump has failed I think.
Checked the manual and the fuse is intact.
The headlamp washers still function so I'm assuming that this has a seperate pump?
Usual checks completed, reservoir is full of water, no blockages I can detect, anyone had the same issue before my Lexus dealer has a look ?
Yes, my pump failed and I replaced it myself, see more details here:
Many thanks for the replies, there is no noise from the screen pump and only a short burst of water and noise from the headlamp pump.
As the fuse is intact its is, as you all suggest, time for a new pump.
My IS is still under the Lexus warranty so when its in for its 80k service next week, at Lexus,they can fix it hopefully within the warranty , well I can hope, if not I shall be buying a pump and changing it myself.  The diagrams and photos are very helpful.
Thanks again for the replies, appreciated.
