Hello
I've got an LPG converted 2003 pre Face-lift LS430 with 178k miles on it.
Changed spark plugs last week. The mechanic noticed small cracks on a few coils.
Since a few days now I've noticed the car doesn't start first time. A crank or 2 does gets it going.
No lights on dash. Recently serviced it also.
I feel that this is the start of some issue that I'd like to resolve before it gets bad.
I'm sure it's not the spark plugs. What else can it be.?
Fuel pump?
Fuel filter?
Injectors?
Please help.
Plug in an ODB2 reader and see if there are any error codes. They don't always result in a warning on the dash.
If it starts after a few cranks and runs fine from then on, then most likely to be fuel pump issues or a clogged fuel filter.
Hi Adam
May be a statement of the obvious - is you Battery in good nick?  You may want to charge it - a big V8 needs quite a few CCA.
Bren
There's your answer ^^^^^^^
If I remember correctly the high voltage side of the coil gives out about 20kV, which can 'track' along any hairline cracks rather than going where it should be, ie, to the centre electrode of the spark plug. Even if some juice does make it to the centre electrode its effectiveness will be greatly reduced if there's any tracking at all going on.
Take off the engine cover and then get someone to start it in the dark, have a look for electrical discharge around the coil packs confirming tracking.
