I have just bought an RC300H and notice that the power socket in the central arm rest compartment isn't working.
im guessing it's just a fuse but can anyone tell me where I'll find it?
Thanks.
When are you using the socket?
"The power outlet can be used when the power switch is in ACCESSORY or ON mode"
Fuse location, check the lid of the fuse box in the passenger footwell
Hmmmm. Switch? Where's the switch? I didn't see one.
It's what the handbook calls the ignition button, the big blue one top left of the cluster..
Oh ok. I thought you were referring to a switch in the armrest storage space to switch between the USB and the power socket.
Yes I had the engine running so I'm back to thinking I need to access the fuse box.
Thanks for your help Nemesis. Much appreciated.
Yeah I've found it thanks. Ordered a few 15a fuses to replace it later this week.
Thabks again.
Fuses rarely blow for no reason. Check the socket for damage/debris and always keep the socket cover closed when not in use. :thumbsup:
