Drivers side passenger door handle
Hi Pat, also check here; https://www.autodoc.co.uk/car-parts/handles-10791/lexus/is
Sourcing from a dealer will be expensive, that's a given.
The older IS handle looks to be an easy job to replace (linked below) and if you're lucky then maybe there is some cross over here to your version?
I haven't done an extensive web search for your particular model so grab a coffee and see what you can find.
Good luck.
