It might be the Aircon Drain plug blocked under car if its ok you should see small pool of water under car just under driver side if the air con as been on. Its a common problem with the US cars
15 minutes ago, NemesisUK said:
The handbook suggests switching to outside air to defog the windows..
Sorry Pete. My error . Recirculating air is switched OFF allowing outside air to be drawn in . Back to my Weetabix !!!!!!!!
Many thanks.
10 hours ago, Andrew peckitt said:
Hi I have a ongoing problem with the windows misting up no matter what I do will not desist air con is on and fully charged any help would be welcome
Had this on a BMW a number of years sago - it was a blocked air con drain pipe as per a previous reply - compressed air can be used to clear it
