Hi All, I've just ordered a 2002 rear left door lock mechanism for my 2004, and I am now wondering if it will fit and if the soft-close will work.
It looks identical to mine, so hopefully it will work and resolve the issue of not locking with the first press of the lock button, but working fine on the double-press/double-locking mode.
It also does not flash the indicators when I lock it and I'm pretty certain this is the cause. The indicators do flash when I unlock it.
Are the door lock mechanisms (actuators) all the same for 2001-2006 or did I just waste £25?
Same part number (69130-50060) from 2001-2006 so same part used, £25.00 is a good price considering nearly $650.00 for a new one. Fitting is fairly easy on the rear doors.
