It's over a year since we traded in our 2005 RX300 but I'm almost sure that it's behind the glove box if I remember correctly.
Thanks, I already pulled all that out and couldn’t find it though.
Must be driver's side then  😁
Had to get to the fusebox on my 2006 RX350 last weekend. Its a v small box with mini blades in. Found it by removing the panel under/behind the glovebox. Has a black cover held in by a clip and sits under the glovebox furthest away from the front of the car. It's not visible unless you get your head right under, or use a mirror or phone to fake a pic. This is what it looks like with the cover removed:
Would be surprised if Toyota had redesigned the electrics system just because of a name change so hopefully it is in same place....
Has anyone got a reference for where to get hold of these mini fuses? I've ordered from a few suppliers on amazon and eBay but regardless of how detailed their description, the mini fuses they send are 10mm length. The ones in our cars are shorter, 8.8mm.
I've seen Halfords do them but I'm loathed to give them £6 for 4 fuses. Anyone doing a selection online for a reasonable price?
Surely you'll have a street-corner-type car accessory shop somewhere near you that you can go in and ask advice? There's about ten of 'em within a two mile radius of me.
Alternatively, have a look here https://en.wikipedia.org/wiki/Fuse_(automotive) or just Google the phrase "automotive blade fuse dimensions" (without the quotes) because you really need to make sure which type you ask for.
That was my view initially. But these have proven to be illusive. I've got the specs, just haven't found them readily available. I'm abroad at present for a while. I guess I'll check with a Toyota Indie once I'm back.
Just wanted to know if anyone has an online supplier they've used.
Cheers.
