One for all you LS fans.. what need to be looked out for on the LS Mk III
Any tips would be ace.
cheers
you must see the stations more than me mate
I always do my homework mate
official consumption figures.
GS Series 1
Urban 19.6
Constant 56mph 34.0
Constant 75mph 27.2
LS400 Series 3
Urban cycle 21.2
Constant 56mph 35.8
Constant 75mph 29.4
I rest my case
Series 3 was the most ecomised engine ever put into an LS... you can see whY!
I think I will bung a IS200 in here too
Urban: Manual: 21.4 mpg
Auto: 20.2 mpg
Extra-urban: Manual: 36.2 mpg
Auto:36.7 mpg
Combined: Manual: 29.1 mpg
Auto:28.5 mpg
oh look.. the IS is not even 1 mile better to the gallon!
LS has much more refinement.
That is unreal i always thought they were gas guzzlers got me thinking now i can sell mine keep half the money ,buy a nice ls for around 4k and tell the missus it is more economical ,that way i still have a lex
make sure its a series 3... they were the most economical.. the series 4 was absolute pants on consumption.
I fisgured this out ages ago... my soarer is worse than the GS... turbos suck it like a straw!
95-97 model is what you want
Auto: 20.2 mpg
Auto:36.7 mpg
Auto:28.5 mpg
This doesn't compare with the LS figures.
The government changed the way the fuel comsumption was measured a few years ago to be more true to life. The IS figures are on the new system, the LS on the old.
steve i took this from the mk1 brochure printed by lexus
GS Series 1
Urban 20.3
Constant 56mph 36.2
Constant 75mph 29.7
still not as good as the ls though
Series 1 figures are as old as the LS ones
colin I know what you mean... but in your mind just hw much better would the IS be?
I have read that the series II was the most economical if you did the figures.
I would expect the IS to be 5mpg better doing the same journey.
That's what I think would be the difference. Nothing worked out. I know the IS is poor on fuel but not that bad. Much lighter car with smaller engine and more efficent drivetrain (manual gearbox)
Look at the fuel figures between the LS MKIII and MKIV. There is a big difference. I would actually think the MKIV is better has they improved economy with each version. However the MKIV appears to be 4 or 5 mpg worse.
The MKIV is tested under the newer regulations and the MKIII under the old regs.
the only way to tell this would be the trip computer in the car.. it should tell you what its averaging...
I read up that the Mark II was the best... but was this because inaccurate figures?
I have read their disclaimer saying that figures could be different due to weather conditions and all
but these figures were tested using the original EC driving cycles under directive 80/1268/EEC
So the mark IV figures are using the old system
Also i always assumed a bigger engine at 57mph would be much more efficient. I would need to see more proof that you are correct colin.. perhaps a few members here could do some tests of their own
The MKIV figures are on the new system. Don't be fooled by the Lexus website - there are so many errors on there. Those figures are for the new regs.
Look at the excel spreadsheet here:
http://www.vcacarfueldata.org.uk/download_data.htm
The car was sold in 2000 and had to be tested with the new regs.
Bigger engines better at speed. Not in my case. My old GS300 is better on fuel than my GS430 even though the 4.3 engine is a newer design.
but that shows the figures on the Lexus site would be something near... we are not saying exact and I appreciate that the figures are an estimate.. but even those figures show the GS430 has higher consumption than the GS300... but compare it with weight and all the other factors like extra CC, 2 more cylinders then its does pretty well considering.
I would say those figures should be 1 mile either way of those figures on the Lexus website. But what i did notice is that I did not see a disclaimer on the IS200 specs... I could go and buy a car with those specs only to find it could be worse... your figures show better.. but still wrong to the consumer.
ok.. i am going off on one.. :winky: :whistling:
I will do some more research!
The figures are exactly the same as the Lexus web site because they are the offical figures for the car, except the Lexus web site states they are on the old system but the government site says the new system.
They must be the new system because the MKIV would not be worse than the MKIII. The MKIV is only a little heavier but has the same drag, more efficent VVT-i engine and has a 5 speed box over the MKIII 4 speed.
It's a bit like the new LS430 over the old one. The gearbox has made a big difference to the mpg.
There are a few mpg figures from members here:
http://www.lexusownersclub.co.uk/forum/ind...howtopic=11597&
so back on topic... anything I should be looking for
i will check for upper arm ball joints
leaky exhaust manifold
dash lights
broken springs
So.. all i need to do is boot it.. that will tell if anything is wrong.
UK ones don't. Not sure about other countries. I think the MKIII has oil filled shocks rather than gas so should be easy to spot any leaks.
ahhh it was the mark 1's that had gas pressurised shocks.. perhaps mark 2 as well?
