Hello,
Has anyone here changed the bulb for the small side indicator on their RX? [ Note the one on the front, but the small side one. ]
My RX300 bulb has 'gone'.
I need to replace it. The manual suggests 'pushing' the small semi-clear plastic cover back/forward, and out...?
I have tried pushing it, but will it move... ?
Not as yet.
Apart from taking it to a garage, has anyone done this or have any suggestions, please?
Regards,
Piers.
similar to this - they can be stiff and only move about 1mm as you push against the clip. Try forwards and backwards, it could have been put in the wrong way.
Brilliant!
Thank you.
Watched the video - bulb changed in a couple of minutes.
Push slightly to the front - it is only about 1mm - and pull out.
Have the bulb ready so you don't lose the cable as it's tempted to go 'back in'.
