Hazard warning.
Stompe
I don't have the CT wiring diagram to hand but I doubt there is one, there isn't on other modern Lexus vehicles as it is directly driven via a flasher unit within the instrument cluster.
There will be a fuse, in the engine bay I believe on the CT, but is shared with the indicators so if they are working then the fuse should be good.
  • 4 weeks later...
