New is300h owner - help needed
Hi to all,
just joined this forum after purchasing my 2015 Lexus is300h Executive edition in Sonic Titanium
Really enjoying the experience and getting used to the hybrid drive. I have tested afew different prius and auris and this is a totally different drive to them, especially in sports mode.
The problem I have is that I have noticed my sat nav isn’t displayed on my instrument cluster, I have read that there is a blue connector at the back of the cluster that connects to the navigation system so that it can communicate. It got me thinking  if it would be as simple as getting the wire and connecting it up myself to get the navigation to show on my cluster or is there more changes needed?
2 hours ago, BIGGY2 said:
Hi to all,
mine only works when a destination has been set, it only advises me of upcoming junctions.
The question I'd be asking is why is the cable missing? Was it ever fitted?
If it was never fitted pretty sure there would be some coding with TechStream to enable the communication.
Do you need to switch to a specific display screen to view the nav info?
I think there is meant to be a navigation icon in the cluster options which mine hasn’t got. Wierd because my car comes with navigation and I checked the back of my cluster and I have the blue connection.
I'm sure all clusters are the same, differentiated only by coding.
As Colin suggests it may only be available on Premium (and F-Sport clusters, as in my car)?
4 hours ago, BIGGY2 said:
Yes it could be a premium nav feature. Could someone with basic nav confirm if they see the navigation option on their cluster.
I have a 64 reg IS 300h Executive with standard nav and don't have the navigation on the cluster.
Thanks, I guess that solves that. I am still going to try to source the wiring loom to connect to the cluster. I will update here if it worked or not.
  • 1 month later...
Any luck getting it working? I am also keen to get the navigation in the cluster.
I tried setting a destination but it doesn’t show junctions in mine. Your cars probably got the plug connected on the back. Do you have basic sat nav or premium?
Mine is the premium nav, but I was under the impression they all did it
