The headlight washers are a bit high, I need to adjust them but I don't know how to do it, can someone help me .
 Sam Case
Hi INorman
Get yourself a decent sized needle and insert it into the hole in the nozzle and move it around until it hits the headlight were it is best ,usually low down as the airstream then shoves the water across the lens as you travel forward.
Needle is ok or you can buy a tool for cleaning and repositioning. I recommend this as it’s less likely to damage the pipe or unit.
silly question...sure they’re too high? They have to hit the lights at driving speed and they will spray up over the bonnet...that’s normal...might pepper the windscreen too.
Well chaps I have tried what you suggested, the problem is now worse the small key I bought was useless, I tried to adjust the jet and the needle bent, the jet now is higher,---Any idea how to remove the  spray jet from the bumper.
    Norman
