Hi Guys,
Have literally only just joined the LOC so  I have no idea whether I'm in the right place or not!
I have a 2004 IS200 with 17"wheels and would like a set of decent wheel centre caps; If I've measured correctly mine are 63mm,
does anyone have a set or advice on the best place to get them?
Thanks a lot,
Chrissie
Is it one of these ?see below,there are a few on the bay
Quote
Hi there, they measure 64mm edge to edge, 54mm inside ring to ring and 58mm outer clip to outer clip! markings on the inside are 2708, 2710, U46 ,>PC and ABS>
WOULD REALLY APPRECIATE THE HELP,THANKS
so are you after the first or the second then ones
64mm probably closer than 63 although it's such a tiny difference, my current ones are black with silver logo and rim
64mm probably closer than 63 although it's such a tiny difference, my current ones are black with silver logo and rim on 17"  11 spoke wheels, have had a good look through e bay and amazon but can't find the exact right size 😐
the caps in the second and third pictures should fit yours
Thanks for your help, yes I saw these but unfortunately they are quoted as being 62mm, no returns, I will continue to keep an eye out but am thinking it may be possible to re-furb the ones I have; at least I know they'll be the right size ☺
they will fit, alternatively try your local Lexus dealer although they might cost a bit more 😊
Yours have the chrome outer ring unlike the black ones on eBay. I reckon you could carefully rub the background down, mask up and paint with spray chassis black or even hammerite with a cheap artist brush.
Hi Graham, thanks for your response, could you possibly let me know either the seller's name or the item number so I can be sure I look at the right ones. Thank you☺
No it didn't, came through as gobbledygook so thanks for your reply☺
