Key question - are both these keys smart?
Just recently bought a LS430.  One of the keys is smart enabled, opens the door, saves having to put the key in the ignition etc.  The other isnt, is it possible to make them both smart please.  The keys are slightly different, so hopefully there is a pic below of the keys. Many thanks.
4-D0501-A9-D36-E-4212-8-D75-39-A1927511-
7-C9-DD2-CA-DE23-437-C-B90-B-F5852048-A4
Mine came with all 3 keys and the key number plate, and they all work as stated in the Manual.
On the Valet key (Sub key) you have to unlock the doors with the button or the pop out key and put the key in the ignition to be able to start the engine.
On your key Mark it looks like the boot opening logo has worn off so it's probably a Master key.
I assume if you push the boot button on the key, it pops the boot?
Left is Valet, right is Master.
Edited by BigBoomer
