Have fully  charged  my Battery, fitted it back in ,all lights  on dashboard lit  up including  starter switch  green, pressed ,absolutely  nothing  dead, please hwlp
Check for feed at starter solenoid when pressing start,if 12v there and main live has 12v change starter.
if no feed start tracing back through wiring to relays etc,have you checked the basics like fuses?
Did you have any 'incidents' when taking out or putting the Battery back in?
apparently there is a meaty main fusible link in the main fuse box that don't take to kind to untoward events!
prob need a multimeter to check all fuses as visually they can sometime 'look' ok buy are indeed failed.
could you have not connected the main cable to starter/solinoid
paul m
If it's an automatic check 'gear' lever positions, that the inhibitor switch has not moved
thanx for the  suggestions, guys,  mechanic  for  me,  it's got  me scratching my head, really  annoying!
