Lexus CT200h Rough Engine
ZoaLex
6 hours ago, ZoaLex said:
The engine kicks is violently when charging the battery, has anyone one else noticed this, is it normal? Thanks guys.
Definitely not normal. It should be just perceptible, and should be returned to the dealer as presumably the car is still under guarantee.
John.
A bit relative. If the Battery charge is getting low and you are stationary it can be a bit rough, especially if cold. It will hold the revs up a bit which makes it more noticeable but not exactly violent.
Could you get a passenger to take a video clip of it?
