Aristo V300 Oil explosion
fasteye
My 98 Aristo V300 decided to empty the contents of the sump on the road yesterday. I haven't had a chance to take apart and find the source and when the AA came out they said basically everything is so covered in oil dripping from everywhere it's hard to tell, they just loaded it up and brought it back.
Engine was still running with no noises prior to me turning the engine off and not overheating. Any thoughts on the first places to look or anyone aware of common failure points which make the 2JZ-GTE engine let go like this? It was due an oil change but it wasn't the way I had in mind!
This was a major spill like with oil pouring out almost as fast as if if the sump plug is removed. Left a trail of oil on the road and the undertray and under the car is covered with dripping oil. I'm wondering if it could be the oil seal on the oil pump gone.
