Hi Guys,
Every time I put the car into reverse the rear camera comes on, which is a fantastic assist when parking. However, once I put the car back into Drive the screen does not revert to the audio screen (as was before reverse engaged) but instead jumps to the map screen, or more annoying still the info screen about which engine is being used.
All I want it to do is to revert to the audio screen to save having to change the screen manually using the "Audio" button - any ideas?
Give a look to configuration menu "automatic change screen" trying changing the selected setting.
It's what mine does - I don't mind.
But STILL finding settings I didn't know I existed.
:newyear:
:newyear:
You and me both. Trouble is I'm having to translate from Japanese first!
On 12/14/2018 at 8:01 PM, Burroo 67 said:
Hi Guys,
Burro,
Are you talking about your rx400h? What is on the audio screen? I have 2006 rx400h with the sat nav and reversing camera, but don't remember seeing an audio screen.
Burroo,
Here's a photo of my main screen. Is it the same as yours? I can't find a screen for audio, as you mentioned.
8 hours ago, Gliderpilot said:
Where yours shows CLOCK mine says AUDIO.
That's interesting.  So, when you press your audio button,  what can you see / do on the resulting screen?
On 12/27/2018 at 12:35 PM, Gliderpilot said:
Quite a lot actually, my system is the ML premium audio unit with a 6 DVD changer.
That's interesting.  But am I correct in thinking that you do not have Bluetooth music streaming, nor an AUX input socket?
You are, Bluetooth only for phone calls.
