This evening  VSC warning, engine light and the ECC light came on (is ECC right? the traction control one) when i started her up.  Car ok just these lights.  Any ideas ?
Many Thanks  Nick
Many Thanks  Nick
It could be many things but you'll need to get a diagnostic check.  Maybe you mean the EML? One of the most common reasons is o2 sensors.  Even a cheap reader should give you a fault code.
2 hours ago, nickd said:
Thanks and it is the 02 sensor,  all sorted for tomorrow!
Is it a downstream sensor (post cat)? Just curious as the pre cat sensors can cause running problems.
It's the bank 1 sensor 1, so nearside before the cat.  I dont know what any of this means as Dave at Lex Tek told me.  I had no running problems though, as smooth, soft and silent as ever.
That's the same as my fault
Can you please let me know what brand sensor he uses as I have fitted a new sensor but the light has returned with the same code showing - I used a genuine Toyota sensor with the correct part number.
My car drives without fault also
thanks for your help
OK, that's good.  Glad you've got it sorted.  Expensive?
It was a genuine Lexus part (does that mean Toyota?) and i was charged £165 + vat for the sensor and £40 + vat to fit.  No more light on the dashboard!
Sounds about right. I bought a genuine (Denso) one for my GS, I got it from Eurocarparts for £145  if I remember correctly, although Lexus wanted £195.
