On 12/10/2018 at 5:14 PM, colin79666 said:
I usually opt for the middle setting. Only a few idiots cut me up at that and it is far enough back to avoid stone chipping from stuff kicked up by the vehicle in front. I go with the longest setting if it is really wet.
How do you change that setting? Mine shows three bars so I'm guessing that is the most sensitive?
Yes, 3 is the furthest distance to the vehicle in front. Button on the right side of the steering wheel changes it between 1 and 3. It has to be on from the stock first and always defaults to 3.
This is from the IS250 Owners Manual but your's won't be a million miles different.
paul m.
