Hi all,
Do you know if the IS300H comes with a jack. I know there is no spare wheel but there is a wrench for opening the wheel nuts and what looks to be a metal long rod like u use to turn up the jack . I don't see a jack there in that area. I didnt check under that plastic panel as its stuck down amd i presume thata where the hybrid Battery is so i dont want to mess about there.  maybe its hidden else where ?
41 minutes ago, byrnew2007 said:
Hi all,
Do you know if the IS300H comes with a jack. I know there is no spare wheel but there is a wrench for opening the wheel nuts and what looks to be a metal long rod like u use to turn up the jack . I don't see a jack there in that area. I didnt check under that plastic panel as its stuck down amd i presume thata where the hybrid battery is so i dont want to mess about there.  maybe its hidden else where ?
According to the manual if it has one it's in with the Battery (left hand side looking at the boot from the rear) - never actually checked on mine...!
24 minutes ago, wharfhouse said:
According to the manual if it has one it's in with the battery (left hand side looking at the boot from the rear) - never actually checked on mine...!
Perfect thanks Phil , il try pull the floor part up to check under it .
Pull the left hand side vertical panel - that's where the 12V Battery is - not the floor
1 hour ago, wharfhouse said:
Pull the left hand side vertical panel - that's where the 12V battery is - not the floor
Ok thanks for that mate 😉
Out of curiosity I had a look behind the panel on the left and I do indeed have a jack in there. Until this thread hadn't ever bothered to check!
Cool i still have to chexk . I did see tge Battery and punture kit but dont recall much room there for anything else . Il double check 🙂
3 hours ago, byrnew2007 said:
Cool i still have to chexk . I did see tge battery and punture kit but dont recall much room there for anything else . Il double check 🙂
Further into the compartment - more towards the back seat.
Hiya i found it looking straigh at me 😂
Thanks very much for your help mate.
Glad to hear that you found it too
