Hi all I'm new here and I have just brought an is 300h advance 2015 and would like to know where the on/off switch is for the front parking sensors and also should the rear ones beep as well as showing bars.
 Thanks in advance for any answers to what is probably the first of many questions.
Lower right of steering wheel there is a bank of switches - it's one of those with the P on it. The "fir tree" light on the dashboard shows whether the sensors are on or off. On mine you can only switch them all on or off and can't select between front and rear (to my knowledge). As above, yes all sensors should beep when close to an object with increasing speed until you get a constant tone. On the display you will see the bars.
You can also set the distance to start beeping near/far and some other configurations in the setup menu in the satnav/radio settings, at least you can if you have premium Mac, the one with the mouse rather than the knob.
You can also change some of these settings with the standard (not Premium) too in the setup menus
