I think that needs to go back to the dealer to have the seals replaced, at the very least.
Agree with the above. It’s not going to get any better. Get them changed whilst under warranty 👍🏻
Thanks, i brought it over to the service center to have it looked at but have had to make an appointment to get it checked out, something about having to run tests on it to determine where the water is coming from. Always thought it was just a visual inspection thing because obviously water is in there so i don't believe it matters where the water is coming from. Also not sure the condensation would be there once i bring it in. Hopefully it can be sorted out.
