Where exactly is the OBDII socket to read the error codes on my Lexus RX400h?
Below the steering wheel, above the pedal assembly. Next to the bonnet release.
I bought this Bluetooth OBD2 adapter, it's highly recommended, not the cheapest but you get what you pay for........
You can leave it plugged in and when not in use goes into standby mode so hopefully their will be no drain on the Battery!
Will report back with findings after I've used it for a while, hopefully it will be all good.
