Hi all iv got a 220d my rear discs are 310 vented does anyone know if the front disc are the same size or are they 296 diameter
I'd say you are best to check for yourself. It seems some cars have vented and some have solid discs. If I was going to guess I'd suspect you may well have 296 vented on the front.
Mine were 296 front and 310 rear and both were vented. This contradicted what suppliers websites said....but then you can't rely on them to get it right. Best to check yourself to avoid getting the wrong ones, in my opinion.
Hope that helps.
The difference is only in rear. Front is always 296 vented, rear can be 310 vented or 291 solid.
