Hi guys. Have recently started to get a drowning noise and slight body vibration in front floor  any one have any ideas , could it be wheel bearings
Try jacking the car up and check the wheel bearings by rocking the wheel whilst holding it at 12 and 6 on a clock. If you feel a knocking then that shows a duff bearing andthe cause of the droning you hear.
Elsewhere on this forum someone else has posted about droning noises. Changing tyres to a branded type cured the problem.
Are your tyres the same on each axle?
Are they a cheap Chinese brand or a trusted brand i.e Pirelli etc?
