Hi All,
planning to buy an IS300H and cannot see where the charging point is on this car, coming from BMW 5 series i don’t think it’s in the same location is it? I mean the cigarette lighter to usb converter.. I don’t really smoke but I need it to charge my Iphone whilst it’s being used as a satnav or to charge the Tom Tom which is a proper satnav
cheers
19 minutes ago, NemesisUK said:
In my RC I charge the phone from the USB port under the centre armrest.
My IS300 has a USB in the centre arm rest also a place to clip the lead in so the arm rest can be closed with the lead sticking out.
IS 300h has under the arm rest 2x USB both of which can charge too although at a low rate and the cigarette socket too. I have a double fast phone charger plugged in the cigarette socket as it charges the phone much faster than the USB sockets. This sits horizontal under the arm rest. I have a USB memory stick in one of the USB ports with my music on it - you need one of the very small thumb size ones to close the arm rest though. There is a special position to bring the lead out from under he arm rest to plug your phone or other device into.
I just use the USB charger to keep the phone topped up whilst connected via Bluetooth to the Navy system, giving me live traffic updates. The phone sits in the armrest cubby out of sight.
Are you doing carrier landings?
NAVigation system
Damn predictive text .... :blush:
I do have the cigarette lighter USB adapter which works fine and will continue using that. Will take it with me tomorrow and will test during driving test.
thank you all for your replies
Unless you need quick and substantial recharging rather than top-ups,  I find one of the USB ports perfectly adequate, with the added advantage of being able to play music/podcasts content more clearly and at a lower volume setting than with BT,  and with accompanying album art also displayed.
