The lc paddle shifters are nicer than the rcf ones in terms of size and looks. Why these are not on the rcf do not know!
Anyone know if they can be fitted?
Stu
Just Googled the LC version, yes much nicer, longer and elegantly curved. They extend below the wheel as well.
Not sure they would suit the more angular interior of the RC though?
Those ones in the link are the standard rc ones.
The lc ones don’t just look nicer (imo) they actually give you a far bigger area with which to use them due to their length.
No reason why you couldn't just fit the entire LC wheel and paddles into an RC. I'd imagine the adapters and coding will be the same.
Had my steering wheel buttons re-coded in my old R32 Golf so the up and down for the volume activated the up and down on my Airrex suspension. It took an auto electrician about 5 minutes so a Lexus to Lexus swap should be very straight forward if not direct!
If you just want to swap paddles then I can't imagine it's not just a straight forward screw out, screw in job, providing you can get the spares!
That’s what I am hoping! It something I will be looking in to.
Thats what i've got on my Carbon...is that not what is in the standard RCF?
The pics before and after are the wrong way around. Ally ones have the black symbols.
But in the description it says..
"Color: Aluminum Finish with ± F-Sport Blue"
The paddles in my RC F-Sport have black markings
24 minutes ago, malcolmw said:
The paddles on the LC are magnesium. Is this the same as the RC-F?
I would imagine so as they were also magnesium on the isf.
Well......
I have to say......
It appears you're right and I'm wrong !!
Soz :)
4 minutes ago, Comedian said:
Well......
I have to say......
Soz 🙂
:toast: :thumbsup:
