Hello, I just bought a Lexus ct200h plate 62 that doesent have Cruise Control. I want to install it but Lexus, Toyota and Halfords said that if the car is not fitted from factory they will not be able to do it. I have the slot for it so that means that CC can be installed. Can anyone help with advice on price and place to install please? I live in Barking,London but I can go anywere in London and around M25.
Thank you so much.
Have a look at the US Prius Chat forum. This is something that can be done for a few pounds as it only require the column switch and a new stop lamp switch. The CT is based on the Prius using the same running gear.
John.
It’s a plug and play. Just buy the cruise control switch yourself.
Lexus and Toyota don’t even know there own cars. Useless.
Search eBay for Lexus Cruise Control, lots avalable from ~£6.00. Fitting is easy and I am sure there are pictorial guides on the web. I was going to do my 2011 CT when purchased but traded in before I got round to it
this is from the toyota forum on an auris
https://www.toyotaownersclub.com/forums/topic/86751-cruise-control-installation-instructions/?page=25&tab=comments#comment-1436477
some dealers just dont have a clue and even more so Halfords
once you have unclipped the airbag remove the blanking plug in the steering wheel and
with 2 screws fasten the switch in place and put plug in the vacant socket on the steering wheel
jobs done.
