Not sure what you mean about voice control button.
 The tyres are standard tyres but the valves in the rims are not the standard rubber type. Externally they are aluminium, and internally they have a Battery operated pressure sensor with transmitter. A receiver in the car picks up this signal to give low pressure warning.
The sensors are £40 each upwards, and are replaced when the batteries go flat. You can replace the batteries for very little money. Do a search on TPMS Battery replacement.
John
14 minutes ago, black400 said:
I have a voice control  button on the steering wheel but it does nothing when pressed,  thanks regarding  the wheels
My GS had the same button, when I pressed it there would be a bleep then you gave it the command.  Mine wasn't great but when i asked it to set the climate temperature it was spot on.
