Anyone else fitted the OEM Toyota mud guards to theirs?
I have been given a set and look ok when put up the car but not too sure?
Just fitted the fronts - they look ok to be honest, wasn't sure at first but they do look good. Easy to secure, took 5 minutes each side, if that.
Will do the rears next week as its a wheel off job to drill two small holes.
I've always considered getting a set to have on the car during Winter, which I would then want to remove again during better weather, but the fact that drilling is required throws a spanner in the works.
You can just use a couple of those plastic tabs and some very sticky sticky tape if you don't want to drill.  They won't be as secure, but probably good enough.
