Has anyone else noticed the level of wind noise on a 300h at motorway speeds?
Mine makes a real racket, if I take the internal recirc off on the climate control its slightly better but still there is a heck of a lot of noise from the lower centre part of the windscreen, I have even close the centre vents and that's not changed it at all.
The other noise I have started to notice a lot is the wiper motor? Not as intrusive as the wind noise but for a premium car I'm really surprised I can hear the motor at all, I was never able to hear it in my Prius.
I'd get that looked at. I was on the motorway the other day and my is300h is quieter than the last lexus I had and that was quiet.
Sent from my SM-G965F using Tapatalk
Can't say i notice any excessive noise in mine either.
Wiper motors are quite too.
I'd get it checked out.
Road noise is WAY quieter then my previous Mazda 6 - that was really bad over 60mph
Sent from my SM-G960F using Tapatalk
My wiper motors don't make any noise at all..
And i don't have any wind noise at speed. As above I would get it checked out. Had the windscreen been changed as that could explain both issues.
if you look on the windscreen there should be some writing in one of the corners
if its original lexus will be on the glass .
Mine has had a replacement screen, it is a non genuine screen.
I don’t know when it was done as there’s no history of it in the info I got with the car, I’m tempted to remove the plastic scuttle and see if there’s anything obvious missing
13 hours ago, Jayw13702 said:
Mine has had a replacement screen, it is a non genuine screen......
Jason:   Please take the following purely as an anecdote and not advice.    I once had a colleague whose Audi TT had a noisy non-original windscreen,
 a fact he had not noticed when recently buying what was otherwise a very nice low-mileage car.   Confirmation that the noisiness was due to badly-
fitted low-quality glass was accompanied by not unexpectedly exorbitant quotes for a replacement by both Audi and a local windscreen specialist.
One day soon afterwards I found him grinning all over his face and gleefully pointing to a long crack in the windscreen caused, he said, by a stone
on his way to work - and which he had already reported to his insurance company.   While naturally sharing his joy at being able to claim 85% of the
replacement cost as per the terms of his policy, I was nevertheless left wondering about what must have been the most welcome stone in the history
of cracked windscreens.
  • Like 4
You mean hammer.....? 😂
...You may very well think so, but I couldn’t possibly say...
Well I decided to have a closer look at this today as this week I have about a 1000 miles of motorway to do and now that I've noticed the noose I seem to be focuses on it now [emoji35]
Stripped the wipers, scuttle and motor assemble out today, there are no grommets missing or holes in the bulkhead, so I moved onto the contact surface between the lower part of the glass and the windscreen aperture, because it's hidden I could only go by touch and it appears that there is little/no bonding agent between the body and the glass, whoever installed the glass put the bonding agent about an inch lower that it should be.
So what you have is a bead of bonding agent that has made no contact with the body, and a gap that is possible to slide a piece of paper between, this would explain my wind noise and ability to hear the wiper motor whirring away.
I had some black mastic in the garage so have run that along the join, not easy when it's not possible to see but I'm hoping that will cure the problem.
I don't know which company replaced the glass as it was done prior to me picking the car up secondhand, however given. Y mileage I'm sure it won't be long before I'm needing a replacement glass. I've had to on my previous two cars so I expect this one to cop for it as well.
I'm waiting for the mastic to dry properly before claiming a total success but I'm quietly optimistic
fingers crossed that you have fixed the noise
i had wind noise on my last IS around the top corner of the drivers door
i gave up in the end and lived with it
