I have just recently become the owner of a 2003 LS430,great car with one or two niggles my main one at the moment is that the sat nav is not working, the screen shows "unable to read data. Check if map DVD is correct. "
Let me explain I bought the car privately from a wheeler dealer fellow who got the car at auction, he gave me the DVD he got with the car, it says 2003 on the DVD but when I put it in the drive although it whirls up as if loading I get the message on screen, I have checked the DVD in my laptop and it seems to read all the files correctly. So my question is where do I go next? Are there codes or routines I need to go through to reset the screen! Or is there any other module I need to check.
Any help or advice would be great
Sent from my SM-G900F using Tapatalk
From experience I would be tempted to say its the wrong disc
It is some time required that the supply to the nav unit is removed by pulling a fuse or disconnecting the 12 volt Battery. for a few minutes. Then reconnect and entre the disc.
John.
Thankyou all for responding to my call for help. Let me expand on what I have done so far.
I have had the DVD unit out of the vehicle to check for damage and function, so that should have disconnected any fuses and electrical connection's. I have made sure the disc is in the right way up, that is shiny side down with label up. I cannot tell if it is the correct disc, it's the only one I have. Would a photo help? If so I will take out the disc and take a snap.
One other thing there doesn't seem to be any power to the multi change CD unit, could this be a clue to my problem? Although the tape and radio work.
I have checked all the fuses since purchase and the only blown one I found was to the cigar lighter, due to being stuffed full of junk (silver paper etc.)
Oh also I have tried inserting disc under various conditions, engine running, not running, ignition off/on.
Although I am not desperate for sat nav, it would be nice to have, as there may be other functions come to light eg. service reminder etc.
Just to clarify the situation are you trying to put the nav cd into the multi changer?
John.
No the DVD goes in the boot DVD drive. CD'S would go in the multiple cd drive if I could get it powered up
Is there any way that you can contact the previous owner to seek clarification as to what he/others may have done ?
To royoftherovers. Not really able to find that out, the guy I bought the car from gave me the DVD in an envelope and when I asked him about it he said that was how it came from the auction house. Although I do have the name and address of the original owner from new, I feel a bit cheeky contacting him. Data protection and all that!
there's a more worrying issue that you might like to consider having effectively bought your fabulous car through the auction
that is:  Has the radiator been changed  ?  to prevent the gearbox water ingress issues
If you know all about the idiosyncracies of the Ls430 then i apologise upfront for mentioning this.
the fact that the system comes up with unable to read disc means that the system is at least working,otherwise you wouldn't get anything. I had a similar situation years ago with my IS200 when I bought a disc off the bay and it turned out to be the wrong 👎 one ,as it came up with the unable to read message. As soon as I got the right one it worked okay and did for 8 years as sold car last year
To scudney. That's fine but how many disc's do I try at £XX each to find out that the fault is elsewhere?
I am aware of this possible problem in fact the lower fins on the radiator are degraded quite a bit the outlet couplings to the transmission look good though.
I'm considering which way to jump, As I only live a few miles down the road from Tony Frost , it might be a good condition radiator v's oil cooler modification. But not necessarily both.
Have you got a dealer near you?  If so it may be worth asking them if the disk is correct, or emailing them a photo of it.  Having done two LS430 radiators I would do it again rather than the cooler, it's such an easy job.  The main thing at this stage is that your connections look rust free.  How about some photos of your new steed?
Around 2003 there were a number of different versions of DVDs around.  I remember buying the wrong DVD for my old IS200 (2001 model).  The error message you describe is the same as what I remember from all those years ago.
If you could post a photo of the DVD you have and a photo of the startup screen (the one that says "I agree") I might be able to work out if the disc is correct and which one you would need if it is wrong.  I have a spare DVD here which I'm happy to send to you, but I think it might be from a newer system.
Here are photos of the disc I received with the vehicle. I noticed it states ver 2002 yet the car is 2003 registered. d97db1daadc1e9687401dfa909e2a2e9.jpg75a4e8c010fadc88badb2280e9b92a38.jpg70a9ed1b51b50d2565efb51e18e7ee51.jpg
Sent from my EML-L09 using Tapatalk
I am not an expert on Lexus DVDs, but in my 2002 car there is this DVD and it works fine, with original DVD drive and panel I think. IIRC it is a last or near last (like a months to last) possible upgrade for this epoch lexus satnav. Just an info.
edit: I found again the website I used to investigate subject, there is pretty good search engine for "what do you have in your lexus, and what is going on" (but not a good prices...), mine satnav is described as Generation 01 by this website:
https://www.lexus-mapupdates.eu
Graham, based on the DVD photo you've supplied I think it is a disc for a Gen 01 system.  However there is a chance (being a 2003 car) that your system may be a Gen 03. (the ver 2002 that you mention printed on the DVD relates to the date the maps were created)
I have a spare Gen 03/05 DVD at home (with 2012 map data on) that I'm happy to send to you if you want to try it.  If you are interested send me a private message with your address and I'll stick it in the post.
As an aside, do you get the disclaimer screen at all when you boot up the system?  If so, from the picture I've attached which colour pattern do you get?
hi Pidster i think your sat nav is a generation 1,if you visit the Lexus map update and enter your disc numbers it comes up with part number PZ445-X01EU-11 - the X01 referring to the generation and the eu11 referring to the year of the update which in this case is 2011.The two discs in the photos above are both generation 1 sat nav discs.
The disc has "Stationery" (in HMSO) misspelled as "Stationary". Perhaps they're all like that, but it does look a bit dodgy....
I have a set of original navigation disks supplied with my Prius when new, and these also have the spelling as "stationary".
John.
Hi pobrown just to let you know there is no disclaimer screen appears. There is only the message unable to read data.
Pobrown, I received the disc you sent me through the post. A very big thumbs up for that, much appreciated. But sad to say no joy still getting the message unable to read data. So I'm going to have one more go at cleaning the laser lense before calling it a day, and accepting that I don't have sat nav, other than on a stand alone unit.
