Hello all............I am a bit premature (Several Months) When checking Antifreeze for winter do you need to use a special antifreeze...or will any do ?
Advice appreciated......... Thank you Royzels....................
Normally Toyota/Lexus use Toyota SLLC ready mixed coolant. From new this is what is in the coolant system, and lasts 10 years or 100,000 miles before changing. There after it is recommended to change every 5 years or 50,000 miles.
Any good quality antifreeze suitable for aluminium engines would do, but perhaps it best to stay with OEM.
Check the colour of your existing fluid if it is pink/red it is possibly SLLC, and just top up with this.
John
Hi............. Thank you very much for that advice........... Cheers Royzels
My coolant hasn’t needed topping up in the 18 months i’ve owned the car, so i’m sticking with the genuine Toyota stuff
And no, generally its the same coolant year round, although you may want to check the concentration is adequate.
Sorry don't know...Perhaps one of the other members can help............Royzels
