is300h indicators
I saw this mentioned elsewhere for a different Lexus, but can you change the number of flashes when overtaking, if so how ?
I do find the indicators frustrating.  It's ok if you are going around a corner and they self cancel, but if cancelling manually, it's so
easy to end up indicating the wrong way, by mistake. Unless I am doing something wrong.
Yes, you can change to standard 3 flashes to 5 or 7 using Techstream or Carista android app with proper OBD interface, or just ask your dealer 🙂
2 hours ago, Zotto said:
Right! I remembered something about, a bit more complicate but with great advantage to need no interfaces.
Indeed. Though, if you're at the dealer, let them do it for you. As with everything they do, they'll probably charge you for doing so.
27 minutes ago, ikeja said:
DIY is far too fiddly for me. Will get Lexus Chester to change it to 5 flashes at my upcoming service
It looks more complicated than it actually is Barry, go on man have a go.
12 hours ago, 200h said:
you can use a special flasher unit to give you the lane change feature
its called tap turn http://www.autowindow.com/features
link for the user manual https://drive.google.com/file/d/0B7M-IwegzU3MTm05MG0zZHRQem8/view
and here is a  video of it
Am I missing something? I don't see the need for this, Is300h has lane change feature. Maybe needed if you want those strobe features.
10 minutes ago, 200h said:
my mistake posted in the wrong place
Happens to the best of us at times.
Perhaps the 250 doesn't have lane change, in which case this may be great!
i'm sure i read on a post i wish i could have this feature or words along those lines
as said i have posted in the wrong place
