So I’ve had all the windows open because if the weather. Now when putting all the windows up, one of the back windows won’t close. It just goes up and then opens up straight away.
Ive manged to close it, by slowing pushing the switch up. Any ideas?
I had the same issue on my Volvo.  Try lowering the window and keep your finger on the button for 8-10 seconds, then raise it and keep your finger on the button for the same amount of time and it hopefully will reset it..... hopefully.
I believe what you are saying is true. If the Battery has been off, you have to reset them one by one.
