How do you disable the steering wheel retracting when I turn the car (GS250 2013) off.
I’ve set the position in the memory but I find it perfectly easy to get in and out the car with the steering wheel in position when I leave the engine on. I’d rather it just stay in rather than wait for it to come out and drop into position.
Also how to I set the climate control so when i change the temperature it changes the other side too? It’s usually just me in the car
Regarding the A/C, there should be an option labelled DUAL somewhere. When checked, both zones will be controlled simultaneously.
Is that in the menu or a button somewhere in the dash
I don't have a GS, but on my car it's a (digital) button on the touchscreen when the climate menu is selected.
I know you can disable the seats from moving when you switch off but don't know if this disables the steering wheel as well. It's somewhere in the general settings I think.
On the AC screen there is an icon called dual.
Same as my IS then. 😎
Regarding the retractable column, it might be one of those things the Lexus dealer can disable (for a price)
Got the seats disabled but not the wheel. Salesman told me it couldn’t be, worth a shot. It’s a first world problem.
