Just changed majority of spark plugs.
Some num nuts had tighten them so bad it is untrue in the past.
The left hand side at the top needed the brake booster removing so I can use my socket set extension. And still no luck. Going to get a cheater bar tomorow to assist. the bottom left the power steering pump is in the bloody way.
Hard work today. Spent approx 4 hours to do 6 spark plugs
A 'little' spray of releasing fluid into the cavity to work overnight may assist.
I've found when they are really stuck, stupid though it sounds, is to try and give them a slight tighten as once they have moved either way it helps to release them - best of luck and protect your knuckles!.
