Hi folks,
How do I stop my headlights turning yellow after they have been polished?Also my alloy wheels are a bit kerbed and ratty. There is corrosion on them so full refurb would be costly  I am thinking of fitting some wheel trims to improve their appearance (car is light blue metallic.) Any recommendations or thoughtd?
Thanks in advance:winkiss:
If the headlights have been stripped of their protective coating then you either need to keep polishing them every couple of years or apply a clear coat - take a look at this video:
That's great. Thank you very much. Do you know if the IS250 has acrylic or polycarbonate headlight lenses?
Hi folks,
Once polished they will need regular top ups of a uv sealant. I did mine when I first got it and keep them sealed / waxed
Sent from my SM-G935F using Tapatalk
I'd assume polycarbonate as it is more impact resistant, and a reason why they yellow.
