Hi All,
Can anyone tell me if there is a fuse box inside the CT200H, i know there is a fuse box under the bonnet but i wasn't sure if there is one inside the car.  I want to piggy back off a couple of the fuses for a dash cam.
Thanks in advance
Roy :-)
I've got the kit to do this too, but although I know the location, I've been unable to get the cover off. It seems to be anchored in somehow. Is the little arrow in the diagram saying to pull the front part down?
The trim panel or the fuse box cover? I think the fuse box cover has a plastic catch which needs to be pressed in and the cover pulled away.
I couldn't get the trim panel off. I pushed a catch in, with some force I might add, it disappeared inside and the cover still wouldn't come off. Hope you have better luck than me Roy.
Sent from my Nexus 6P using Tapatalk
It does unclip quite easily and drops down for access. Unclips from the back if I remember?
Mines due to come off again as I need to replace the 15A fuse for my Aux socket in the console. That’ll teach me to use an inferior car hoover which blew it.
