Recently my lh headlight went out, so after removing and purchasing a new one, not at the highly stupid prices Halfords charge I tried to fit. This in itself is quite tricky but I managed to do it but it didn't work. So I checked the relevant fuses and these are fine also so am hoping someone can out me in the right direction for a hopefully cheap quick fix.
Sent from my G8341 using Tapatalk
As above Andre, gotta check what's good through a process of elimation. new parts have been known to be faulty out of the box and consequently you assumed bulb was faulty when problem occurred so need to check if the known good bulb ( your existing RH working one ) still works in the LH side. If it does then new bulb is faulty if not then ballast/wiring issue as you say fuse was good.
Paul m.
Cheers for that, will have to have a go at that tomorrow then. Hope alls well tex
Yes all good here mate and hope you get a result soon :)
paul m.
