Hi all,
I bought a Techstream system off fleabay and it has yet to connect. What's worse is that now my old ODB2 scanner can't connect either. It says "Cannot connect to ECU".
So, can I reset the ECU by disconnecting the Battery for 10 mins?
Does the radio have an unlock code if I do disconnect the Battery? (No I can't find one in my documentation)
Thanks all :D
Hi all,
So, can I reset the ECU by disconnecting the battery for 10 mins?
Does the radio have an unlock code if I do disconnect the battery? (No I can't find one in my documentation)
Thanks all :D
My 430 is a year 2000 and no radio code
Sent from my GT-N7105 using Tapatalk
Well, did the Battery disconnect but still can't connect to the ODB2. ☹
It did reset the Check VSC but that will come back after I drive it for a while. I'll get around to doing the lambda sensor soon.
The ODB2 scanner is getting power but cannot communicate with the ECU.
Any ideas?
2 hours ago, BigBoomer said:
Well, did the battery disconnect but still can't connect to the ODB2. ☹
Any ideas?
Is it simply because it's a Chinese copy?
