Have you read this thread?  The Sensor has a Heater circuit & a Sensor circuit, the fault in the following thread was the sensor Iirc but you have a Heater fault showing in the same component so after checking physically for and damage to the wiring going to the sensor the procedure will be the same.
paul m.
