Rear suspension stuck on high ,Pumped up solid.
Put on ramp with wheels hanging to try to reset ,no luck.
Checked current going to rear ride height sensors ,ok.
Disconnected Battery for a few hours did not work either.
I cant get it onto a computer to test for codes till tomorrow.
i have tried removing compressor fuse etc,trolled through LOC ,no real answers.
502k kms on clock most on lpg.
Anyone experience and resolve the same problem?
Any ideas.????
Ls 430 air suspension is starting to feel like Triggers Brush :withstupid:
You need to check and replace the rear ride height sensor- these are prone to water damage and fail or start malfunctioning
wow, 312,000 miles  ( 502k kms )   that's impressive .............  well done
The extra moisture in the beautiful Emerald Isle may indeed have contributed to this common sensor problem.
If the current is being received at the sensor then it does seem the most likely culprit.
My recent scare did make me look at coil-overs (I recall a whealer dealers episode where they did the same to a Merc with excellent results) but while they can be made to work at a reasonable cost, it pays to keep things stock.
Thanks for your help everyone.
It was indeed the rear right ride height sensor.
Replaced it with a new one now everything back to a nice smooth ride.
I nearly considered flying to New york on Norwegian Airlines for 99 Euros each way.
Price there was 230 Euros/ New.{230+99+99=428} I might consider it in the future.
I paid 425 Euros here/ New.:happy:
