Hi everyone. First post here and wanted to see if anyone has changed the lower part of the fsport grill? I am thinking of removing the license plate to give the car a cleaner look. Was thinking of installing a magnetic custom mount or a tow bar license mount just to keep the coppers happy.
But I noticed that after removing the license plate the garage has drilled 2 small square (clearly noticeable) holes on the lower part of the grill which is used to screw in the license plate.:angry:
 Would love to know if anyone has did this mod! Thanks all
The grill is 1 piece and therefore the whole unit needs to be changed. Not cheap from what I've heard either.
are you sure? Pretty sure I took the bumper off the other day and it is comprised of an upper and lower grill
Thought you had a 2017 facelift one - thats a one piece grill - apologies
Yes the 2013-2016 ones had 2 piece ones which join together. In the UK the dealers will sell the whole grill as a piece.
Perhaps this link may help?
https://www.ebay.com/itm/Lexus-IS250-IS350-2014-2015-OEM-F-Sport-FRONT-LOWER-RADIATOR-GRILL-52112-53070-/131480706800
